DaBank
I have a 2017 JKU Rubicon Recon with a Fabtech 5" Long Arm Crawler kit with aftermarket drive shafts, adjustable trackbar, raised track bar mount, Copper SST Pros 37x12.5x17, Fuel 17x9 4.5 wheel's, winch, front and rear bumpers.
I just had a Dostech Aluminum Tie Rod/ Drag link flip installed and now going to have it aligned this week .
Was told by Fabtech that the kit uses stock Jeep alignment specs. They said that .5 more caster on the passenger side is ok to help with the crown on the road.
I always thought caster on a lifted Jeep required more caster than stock?
What is the best toe in 1/16 or 1/8?
I want all the arms adjusted to make sure everything is squared up.
What numbers should I be looking at on the alignment print out?
