PrestonBarringer
My jeep is bouncing from line to line it's a nightmare to drive. When I replaced the ball joints is when this all started I took it to get aligned and my caster was way off. I fixed my caster by putting on adjustable control arms so I figured this would fix my swerving problem but it didn't so back to the alignment shop now my caster is perfect and my camber in my front passenger wheel is off. Both my rear wheels are toed towards the driver side and camber is off in them as well. The tire shop was clueless on what is causing it. I know adjustable ball joints can fix the front but that seems to me like just covering up the problem. I'm still running my stock Dana 30 in front and 35 in the rear. I was told by a 4x4 shop that my passenger side front axle is probably bent and that Dana 30s have a weak spot on the passenger side. I'm not running gussets like I should and as soon as this problem is resolved I will. Soo I need help what does everyone think axle bent or knuckle? Everything appears normal but that doesn't mean something isn't slightly bent.
