Birth of Phoenix
Finally installed my EVO carrier. It’s been sitting in my garage since I left for VA. Install wasn’t bad. I’m glad I didn’t do the skins and carrier same day. I don’t think my patience would have lasted. I’m really happy with how it turned out. It’s nice to have the back available again. Here’s some poser pics. Didn’t really take any for the install other than the sketchy part that my wife wasn’t happy with. [emoji23]
Your rigooms great. Tire carrier [emoji106]
Sent from my SM-G965U using WAYALIFE mobile app
Finally got the Jeep out and tested the new long arm. Everything went really well. I can notice the difference with the tire climbing a rock. Much smoother and not forced. I disconnected my Antirock because I wanted as much flex as possible. If I disconnect, then I need a little more bump. Limit straps are needed. But I want to wait and see if I’m going COs or not. An aluminum tie rod might be in the future as well.
Knocked out some things that needed to be done. Replaced the axle seals in the D60. The carrier was fun pulling out and putting back in. The old seals came out with the shafts which is a little concerning.
Also I finally swapped the my T Case out for a Rubicon case. It sat in my garage for about 6 months. The top two bolts suck. I can lower my crossmember because my lower links bolt to it. Finally figured out a solution with a crows foot and going back to front. Didn’t work for the other one so I cut my wrench in half and used a ratchet strap to break it loose.
