He folks, I am about to line up a few new projects, was looking for advice. I had thought my ball joints were worn, but I went out to take a measurement with my dial indicator and I only see 10 (0.010) showing for the vertical run out... I think if I remember reading right the limit is 0.050 vertical (Axial) and 0.060 side to side (Radial). I get nothing I can see when I look for side to side, but I can use the pole test method with one side off the ground at a time and I can visually see movement up and down on both the upper ball stud and the lower ball joint... but I get about 0.010 for the reading... I am unable to feel anything by hand (9-3 o'clock and 6-12 o'clock) but I can see the movement I mentioned with the pole on both sides... Thoughts? looks like they are OK... I can however get movement up and down on the tie rod ends by hand, I can push up and it will move enough for me to feel and see on both sides... I don't think this is acceptable... I was about to order the Teleflex ball joints, but if they are fine I will switch to tie rod...
I will re measure again tonight as my dial indicator was at an angle and not 90 deg. which means it couldn't have been precise... but still the difference between 0.010 and 0.50 is pretty big.
