Bottle Jack
SLO
Not that bottle of Jack.
Has anyone found a bottle jack that fits in the compartment that the factory JK scissor jack is stored in? I’m sure there are small bottle jacks that would fit but I was hoping for something that actually has the load rating and height for a heavy JK.
BaddestCross
You can actually fit a fairly large bottle of that Jack in there. Or several small ones. 🤣
SLO
Even funnier that I’m on a flight right now with an airline bottle of Jack. I could fit a lot of those in there but all that would really do is drown my sorrows if I actually needed to jack up the Jeep on a trail and opened the back to realize it sounded funny at the time...
Sharkey
Word Ninja
A little pricey but I’ve been looking at picking up this package. The attachments could really come in handy and add safety to the use of a bottle jack.
QuicksilverJK
I have used the Safe Jack accessories and while they are nice, I feel that they are way overpriced for what they are. Any standard bottle jack will do the job. But as far as one that fits in the stock location I'm not sure.
Steve Williams
Agree, I went with just the accessories, and I’m really glad I did. The universal lift pad that just fits our axles up to 3.5 in. dia. should be in every Jeep with a bottle jack. $29 is cheap insurance that says your axle is not going to slip off the jack. Made in the USA. Great customer service too.
SLO
Good find. Thanks guys.
As for swapping out the scissor jack, I may just have to test a few to see if they will fit. I have a couple extra ammo cans I could use but I have so much crap, I am running out of room for camping gear. Trying to bury as much stuff under the floor as possible.
catahoula
I would definitely change out the scissor jack. Mine almost failed while I was changing my coils. Now I have a bottle jack behind the seat. It takes up space and i feel it is safer too.
benatc1
I have the safe Jack and it is very nice along with all the accessories, I recall it being expensive but got some killer deal back then on a sale they wrte running. Most bottle Jack's will do the job but the attachments are a bonus
dillard09
I also have SafeJack stuff. Mine came in a nice red bag. It was pretty expensive but my bottle jack took a shit so I needed everything anyways.
Ruvicon
I bought a 4 ton Harbor Freight bottle jack that fits where the scissor jack was. I also leave a breaker bar and socket just below it plus a 7” 4x4 in case I need a spacer. I’ve used it often and it lifts the Jeep just fine and all fits in that compartment.
jesse3638
Did you remove the plastic insert that goes on top of the rear cubby?
notnalc68
That dude from Mississippi
I have one in a plastic case. I got it either at Walmart, or Lowe’s. Can’t remember. I bought it, because the case was nice to carry it in the back of a Jeep.
SLO
After spending an hour on Safe Jack’s site, I’m sold. I’m a sucker for that sort of stuff but looks legit.
Regarding 6-ton jacks, most have around 6”-7” of ram travel. Is that enough to get the tire off the ground? I know it depends on suspension and how much up travel a setup has but 6” doesn’t seem like a lot.
notnalc68
This is supposed to work with most 6 ton bottle jacks. Still pricey, but would save someone that already had a jack a little coin.
Regarding the jack travel, most people carry a couple of blocks, like a 4x4, or 4x6, and maybe some 2x4 blocks.
:cheesy:
Regarding your question, you could get a 2-ton jack to fit, same as the scissor jack but you really want something more robust. Just carry it in the cubby.
