Cam Shaft Problem (Exhaust on Passenger Side 3.6L)
ztitans1
Hello. I am hoping I can find some help here. When removing the valve cover there is a piece of round plastic like a cup that came loose from the rear of the exhaust cam shaft on the passenger side on our 2015 JKU. I was going in to replace some noisy rocker arms which is done now but this cap keep falling off when I try to put the valve cover back on. Is this piece necessary? Below is a stock photo. The left side shows the plastic part I am mentioning.
I tried adding some adhesive in the hopes it stays on but I am curious if it will do fine without it or do I need to replace the cam now?
  • 41tB4LL5MvL._SR600,315_PIWhiteStrip,BottomLeft,0,35_PIStarRatingFOUR,BottomLeft,360,-6_SR600,3...png
