P Pastor Scott New member Feb 15, 2016 #1 Have a white fiberglass antenna and want to paint it or cover it black Will that stop it from working ?? thanks Ps Scott
10frank9 Web Wheeler Feb 15, 2016 #2 I wouldn't do anything to an antenna that could interfere with its performance. Why not buy a black antenna? Firestik RP4-B 4 ft. Black .63 Wave Cb Antenna https://www.amazon.com/dp/B005AUIWGE/ref=cm_sw_r_cp_awd_q3tWwbP8C76CG
TLife Member Feb 15, 2016 #3 As long as you aren't covering it with any sort of metal or altering the length you won't notice any performance difference.
Uncle Jimmy New member Feb 15, 2016 #4 Yes you can paint a fiberglass antenna any color you want too... It won't interfere with performance.... As TLife said don't cut the length and you'll be fine....
K Kavanji Member Feb 15, 2016 #5 i use heatshrink on my antennas regularly without any negative effect
AllAmericanInfidel Caught the Bug Feb 15, 2016 #6 I've seen the black fire stick antennas with adjustable tip for less than 20 bucks. You can pick them up at almost any online vendor.
