Control arms
Rookie1
Okay guy, I’m about to lift my 2013 JKU Rubicon 3.5in. With doing so I know I need to replace the Front Upper Control arms with adjustable arms. My question is do I need to replace the upper rear as well?
You’ll want to replace the front lowers. You don’t really need to do the rear uppers on a 4 door.
Sequence Question
Sorry to resurrect this old thread.
I'm in the process of my lift build and I wanted to doublecheck.
If I'm not changing all the control arms, start with the Front LCA's, then what's the next best after that? Rear Uppers?
Thanks!
Thanks!
The purpose of adjustable rear arms is to enable you to rotate the pinion up so its more in line with your drive shaft. This helps avoid driveline vibrations. If you are still running the stock driveshaft, this is less of an issue. If you have an aftermarket shaft with u joints, then the adjustable arms will be a good idea. Of course, all of this assumes you have a lift that’s 3” or taller. If you do not, then the stock arms should be fine.
Got it
2" inch lift, I'm not replacing drive shafts at this time. Trying to get a high quality lift and fit my 285s nicely without a bunch more complications.
Thanks!
Thanks!
You can run 285s stock if you aren’t going to flex it. If you are, all you would need is flat fenders and/or wheel spacers.
Thanks!
You can get EVO 2" coils in front and pucks in the rear. I got some nice flex with my 2 door....running 295/70/17's.
For fun
Let's say that I just felt like spending more money, would geometry brackets (ie AEV or Rancho) be a better solution for the front as compared to front lower adjustable arms?
