Journeyman
So this wknd I discovered a little mouse house on the top of the motor of my 13 jku underneath the engine cover. So the little bastard chewed through the insulation on three of 20ish gauge wires on the wire harness, but amazingly enough didn't damage the conductors. One of the wires was easy enough to separate and put a temp tape job on, but the other two are twisted together before the split apart and there's no way to separate them without cutting them. My plan is to cut these three, then install heat shrink and then butt slice them back together and apply heat shrink accordingly.
I stopped by the jeep dealership today and they informed me they would repair this exact way. But this was from a service rep and not a tech!
The jeep still runs and drives but has been popping an implausible communications code and my sway bar disco light has been flashing on startup. I'm thinking it's hopefully the two wires twisted with the conductors exposed tracking together without the insulation separating them.
Thanks for the help and thoughts!
