on a 2012 JKU with a 3.5" lift and 35's, and 4.5 in backspacing on wheels?
getting new wheels and tires installed this weekend
short answer - NO
If you mean that your new wheels will have 4.5" of back spacing, no, you will not need additional wheel spacers.
thats what i thought but as the time draws closer I'm nervous they won't fit as I've seen others say with similar lifts and tires, they still have spacers or rub at full turn
4.5" of back spacing isn't ideal but it will be enough to work. Your rear sway bar links will clear just fine but you might see some rubbing at a full turn especially if your axle is off center a bit. You can add washers to your steer stops to correct for this - cheap easy fix.
whats ideal back spacing? it was recommended to me to get as close to 5 inches as possible, to keep the tires from sticking out too far as in PA tires can't extend past the fender flares
Being that you have state specific requirements, that is what would be ideal for you.
I'm thinking closer to 5 will more likely rub and 4.5 or closer to 4 or less won't rub? is that accurate, just curious as i already have the wheels
I'm from Pa as well (Pittsburgh area) and honestly I don't understand why guys stress so much about tires sticking out past the fenders. Seriously, I couldn't count how many Jeeps I see every day with the tires well past the fenders. Mine stick out a full 3 inches and I have never ever had an issue. I was even in an accident two months ago and with 6 officers on the scene not one word was said. My nephew is an officer and I asked him if he would ever pull someone over for the tire issue and he just laughed at me and said never. Now he did say that if he pulled someone over and they were giving him shit about the stop, he'd be sure to add the tire violation to the citation.
I think those guys that run the diesel pickups with the low profile tires that stick out like 6 inches or more would have more to worry about than you would with maybe one or two inches. If it makes you feel better ask an officer for his opinion. They aren't boogermen. They'll give it to you straight.:thumb:
More concerned about the inspection. Those guys don't want to put their name or shops name on the line. I doubt cops would care, kinda like full tinted windows, they may pull you but if your cool, respectful and on the up and up, their not gonna care or cite you.
