Driveshaft
Clean off diff and recheck, but looks like pinion seal leak.
Upgrade driveshaft to one that has a double cardan ujoint design instead of the rzeppa style.
Ah ok. There's a place out here called Carolina driveline. Family run place. They've been exceptional to work with. Not sure what the cost of shipping would be but just an option.
I have adjustable lower control arms .so can i just replace pinon seal & then adjust control arms
Sent from my SM-G900P using WAYALIFE mobile app
Buy an analog angle finder. Set you caster angle at 4+. The driveline angle will be proper when you do this.
https://wayalife.com/showthread.php...nt-End-Alignment?p=42391&viewfull=1#post42391
EDIT:The info I posted is for setting caster and driveline angle. The info is not for replacing the pinion seal. You do not have to mess with arms to replace the pinion seal.
