Hi guys! I've been lurking on here forever and finally decided to make a quick post.
I'm looking to install the EVO Enforcer lift on my 2-door 2013 JK Rubi to run a set of 37's. With the kit itself and the Currie rear upper control arms, it looks like I'll have everything I need. My questions are:
1. I'll only need the drag link flip for the 4" and not the 3" if I've read correctly.
2. Will I need to order the front and rear DS after the install so that they can be measured and made to size? Or if I were to order a standard 1350 front and rear (either Adams or JE Reel) off of somewhere like Northridge would the standard length be sufficient? Can I go ahead and order everything I need now?
3. Would it be wiser to run 1310's instead of 1350's since I'm running stock axles? Allowing the DS to fail before the axle would potentially.
I'm having a professional install the kit, and I'll be assisting (probably just fetchng beer and whatnot :beer
learning as it's done correctly. Just want to make sure I'm asking the right questions as this is my first lift and more importantly my DD :thumb:
Thanks in advance guys. You make this hobby possible for people like me.
