No problem.. And there should be NO need to go 3 in Just because you're putting on the Rockstar skids...
I'm running the 4 in plush rides and ordered the rockstars later on from Drew at Off Road Evolution ... He said You just need to check your shock length. The Rockstar skids should be just fine with a 4 inch lift, you're just going to require new shocks if you're going from a 3 inch to a 4 inch lift for the front... more than likely. The rear should be ok.
 The Rockstar skids were originally designed to have the shocks moved up an inch and a half because the King coilovers we're an inch and a half short. If you're running a 3 inch shock you just need to cycle through on the rear and make sure nothing binds up or bottoms out. If you have any questions I would contact Off Road Evolution. Or any of the other reputable suppliers on here and discuss it with them.
You can pm me If you have anymore questions or I'm sure someone else will chime in
Sent from my XT1585 using
WAYALIFE mobile app
