jeeeep
Ok, I will try this tonight. Thanks for the step by step breakdown. Why do you say never use ATF?
I should have changed that since you have your stock steering. check the color, if it's red it's likely ATF+4 ATF, if it's clear it's likely Mopar power steering fluid +4. Jeep allows either fluid to be used.
PSC only allows power steering fluid in their pumps.
