So do you have to get it in place before you slide the D-ring into the frame?
I have the rear fascia and D-rings. So far it is mounted with the two stock bolts and the rear bolt supplied. How the hell do you get the front bolt with the wing nut installed. Obviously, I'm not that talented. Thanks for helping me out again.
I gave up and drilled holes underneath with a step bit just big enough to get my finger in.
