Fox shocks
bran996
For sale I have fox shocks 2.0. Good for up to a 3.5 inch lift. Less than a 1000 miles. Im going with a bigger lift and these just wont work. $400 located in hesperia, ca
Do they work without a lift. I have a stock Rubicon 2dr with 33's that I'm needing some nice shocks.
the box says 1.5"-3'5" ...they might fit but will probably hit something or bottom out ..(?)
Not sure will have to double check. But they where put in on the last lift when the previous owner had it
Thanks Rayz, i didn't even see that.
They're longer on both ends. You'll over compress your springs and then you'll have your springs unseat as they extend. I have the 1.5-3" in the front of my rig with the EVO leveling springs and these are the longest shocks I would recommend...any longer my springs would unseat. Without bump stop spacers you will over compress.
