Speedy_RCW
I watched a video on changing from the stock driveshafts to the Cardin style and it
requires a 1.5° positive tilt to the pinion. Anyone know about the difference requirement
on pinon angle ? Or is the video incorrect ? Thanks!
It's all going to depend on lift and length. With a double cardan you ideally want the pinion and shaft to have no difference in angle. Basically point the pinion at the transfer case output shaft. Most likely you'll have to find a happy medium between caster and ideal pinion angle.
