GraniteCrystal build thread
GraniteCrystal
OK, setting aside issue of bump stop for now so I can finish the rear. First problem of the day: stripped lug nut. Anyone seen this before? How did it happen? How do I get it off? The thing is bulged outward like it just took too much pressure or something
That sucks. Discount Tire stripped one of mine once putting on new tires.
GraniteCrystal
Problem solved! I was afraid I was dealing with a stripped stud on my Spidertrax spacers, but I was more fortune than that. Turns out the lugs have a case on them and that's what was blown. I took a chisel, used a mallet to hammer it into the center of the lug, then took pliers and pried the case off. Underneath was a perfectly good lug that I could put an 18mm socket on and it came right off. Stud on spacer is completely fine.
Journeyman
I've never experienced this. But I was advised by a friend to replace these to one piece lug nuts when I upgraded my wheels and tires, for this exact reason. Glad to seeing worked out.
GraniteCrystal
Got the link for the ones that you put on yours? Or did you just get them from the dealership?
GraniteCrystal
Back at it tonight. Putting on rear sway bar links. Eddie's write up has the grease fittings racing forward. Didn't make sense to me and TF calls out they should face rear, so I'm removing and flipping them around.
GraniteCrystal
Next issue: break lines don't fit in brackets. I can still bolt everything but the old bracket doesn't fit in the groove of the new bracket with holes lining up. I think it'll be alright though.
GraniteCrystal
Done. Still need to realign steering wheel and release bound up bushings (recommended not required) but I drove it tonight, just in front of the house. Can tell I'm higher up and it looks a ton better without the rake. I'll post pics tomorrow.
All in all, about 20 hours. Longer than expected. Would've been shorter if I hadn't run into some hiccups along the way. An impact wrench would help too.
JeepJeep75
Nice job dude!! After installing my Enforcer lift I'm pretty beat up too. All hand tools and crawling around on the ground isn't as easy as when I was 20 something. An impact gun is now at the top of my wish list.
GraniteCrystal
Completed pics
Here are some before and after pics. Left column is before. Right column is after.
And here are some more after pics (our road slopes down from right to left)
Also, this happened last night. That's a rope tied from roof rack to tree in order to line up the rear tie rod. Desperate times. Desperate measures.
GraniteCrystal
3rd break light mod
Ok, I haven't seen this exact version of 3rd break light relocation anywhere but I'm sure it's been done before. Nonetheless, I'm proud of how it turned out since I was making it up as I went along. It was inspired by a pic from BdugJK.
What you need:
Dremel with cutoff wheel
Blue painters tape (other tape would work too)
2-3 hours
Here is the finished version so you can see what we're going for:
First, while the tire is still on, put some blue tape up at the highest level you want the light so it still shows between the slots in the wheels.
Next, unmount the brake light by removing the 4 torx screws on the back. Mark it off a few inches from the bottom so that it will sit at the right height:
After the cut:
Next, use tape to mark out the shape of the cuts. I have a right angle in mine, but you could do a nicer sloped cut to match the contour of the top piece.
Next, remove the actual light from it's housing so it's just the metal portion. Now cut some slots in the metal portion so it can slide over the lower mount:
Post cuts you can see how it fits over the bottom portion:
Next up, trim off the rest of the base piece so it just comes up to the top of the light holding piece:
Next, place a large piece of cardboard over the bottom portion and spray paint the cuts:
Here is the final product:
GraniteCrystal
Got sick of the license plate under my seat, so I zip tied it to the front bumper skid. Anyone had issues with it falling off when attached like this?
8POUND
Yes they do, but most LEO don't worry too much about it. Stay out of Downtown Denver though. It's a $75 ticket. That's why I put my front plate on my skid plate. It's low, but legal.
AllAmericanInfidel
Have you seen the JCR front plate mount? I'm considering it because Hawaii requires a front plate. I've also though about just mounting it to the front grill lol.
