Head lights cutting out
Kwestie
While driving home the other night, my JK's headlight s just cut out on me. I cycled the switch and they came ob and immediately went off again until they just stopped coming on all together. They worked fine again after that and then it happened again.
Park lights and fog lights worked without any issue
Has anybody had the same problem? Perhaps a solution?
Thank you in advance
If you have a headlight relay as well, that may be a cheap and easy part to replace if your connections at the lights are tight.
Thank you guys for the replies, was out of range of a pc for a while.
Stock headlights, found the cable/plug leading to the fuse box (large green connecter) but no relay??
unplugged all of them (grey ones) to test with no result.
Maybe not a standard looking relay?
I would check also to make sure there is no corrosion in the stock connectors. If there is I am not sure how to clean it, but that could be your issue. I use dialectric grease now on connections like that just incase to protect now.
