If Tazer supports firmware updates, is your Tazer updated to support the 392?Ok. Got the Jeep running. Disconnected the battery for about 10 seconds and she started. Plugged the Tazer back in Jeep won’t run with the Tazer.
Purportedly yes. I went thru the Z Automotive help bot. It had me try several things. Nothing worked. I will have to try to contact them tomorrow.If Tazer supports firmware updates, is your Tazer updated to support the 392?
This^. If you haven't already done this.I ask because you HAVE to do the two sleep cycles before any of the changes take effect.
Nope. Car has 2000 miles on it.Do you have an aftermarket security system?
Fixed it for you.Nope.CarJeep has 2000 miles on it.
Thanks!!Fixed it for you.
