I will try to make this a clear as I can.
2022 JLU Rubicon 7,100 miles 3.6Etorque w/ auto Mini Tazer, LoJack ,Warn Zeon 10-S and Baja Designs Squadron Fog lights hooked up to AUX 1 factory switch. These are the only "electrical" mods done on the Jeep. Have had no warning lights of any kind or any other issues. Battery died today (dropped to 10.4 volts) was driven last night and I had just scanned all the gauges and it was charging at 14.2V as it should. Lojack sent a message the battery voltage was low. I went to start it as I thought that was very odd and sure enough, it was dead. Finally got the battery to take a few minutes charge and it fired up. Battery voltage would not go above 13.5 at idle or driving. Took to dealer as its still under warranty, figured the battery had just crapped out. They tested battery and alt/generator and said everything tested fine. They couldn't replace anything because it all checked out. Ok I get that. I asked the tech why it was still only reading 13.5V and he could not give me an answer (he had no clue honestly how the system worked).
Drive home, runs fine, still 13.0-13.5 battery voltage tho. I disconnected winch, fog lights and tazer. Did a quick amp draw test and my meter instantly spikes to 17 amps! When I do the test I can hear a relay click off and on. I tired to isolate it with no luck. Anyone have this happen or thoughts? Going back to dealer in the morning (and requesting a different tech) to have to start a parasitic draw test.
