How often should I change my differential fluid
bl17z90
As the title says, how often should I change my differential oil? I have a dana 44 in the rear and a dana 30 up front. Is there a difference from front to rear on how often it needs to be done?
Nevermind I just found it.....:doh:
But I was curious if anyone knows if the sports with 3.73's are limited slip differentials or not.
It will say LSD on your door sticker or it will have some on the axle tag/door tag if its LSD. It's not a standard option I don't believe.
Thanks. I realized I am at 40k and havn't touched either of them yet......Do you do both front and rear at the same time?
It always surprises me how many people have no idea what their jeep came equipped with when they bought it??
It shouldn't surprise you. Lots of folks buy a jeep because they just want a "jeep". It's not until later do they get into the hobby itself. This particular guy is now learning about his jeep.
Shoot, I bought my first jeep in 1993, a 93 YJ. I decided I was going to get a Wrangler and bought the first one I looked at. Bought it in October and it wasn't until April that I realized it didn't have AC!!
Yup, when I bought my JK I didn't knew half of what I know now. The jeep dragged me into the wayoflife and I will gladly repay her with upgrades :D
X3...my old YJ was the first to teach me anything about Jeeps. Since I have learned so much, but back then was clueless! Noobs are always welcome here, as we were all one at some point! :thumb:
Sorry to dissapoint you. I actually bought my Jeep because it was the only SUV style vehicle I could afford at the time and then just like every other story you hear I got hooked :yup:
Thanks for the input guys, I assume it'll be written on the sticker on the rear axle....if its even still legible.
Do you have the owners manual? there is a section that tells what fluid to use for each type of differential, if you don't have the owners manual you can request a build sheet from Chrysler http://www.jeep.com/jeepcares
the front I believe is the same for all axles is 80w-90 GL-5, the rear will vary depending on axle and use - if you have trak-lok it will require and additive
I forget what the schedule is for normal use but I change mine about every 12000 miles (I tow and drive more than average)
found this on the owner CD - I have a 2010 Rubi Unl:
226 RBI (Model 44) - MOPAR® Gear & Axle Lubricant (SAE 80W-90) (API GL-5) or equivalent. For trailer towing, use MOPAR® Synthetic Gear & Axle Lubricant (SAE 75W-140) or equivalent. Models equipped with Trac-Lok™ require an additive.
If your changing them from mileage then yes. If you got water in your diff or need to check a diff there is no reason to do both.
