JT@623
Turned out niceWrapping up this build. Really happy with it and like the stance of the 42’s with 72.5” wide axles.
Thank you. Drives great too, almost forget you are on 42's.Turned out nice
Very nice! What gear ratio in the diff turning those 42’s?Wrapping up this build. Really happy with it and like the stance of the 42’s with 72.5” wide axles.
Thanks! 5.38’s. This is also a manual 3.8LVery nice! What gear ratio in the diff turning those 42’s?
I was going to ask if it had a V-8 swap. I can't imagine running 42's with the 3.8LThanks! 5.38’s. This is also a manual 3.8L
Actually didn’t feel bad. He doesn’t daily it though and trailers it everywhere.I was going to ask if it had a V-8 swap. I can't imagine running 42's with the 3.8L
Makes it a little better. Still stepping on the throttle and hearing a whine vs a roar just isn't the same...hahaActually didn’t feel bad. He doesn’t daily it though and trailers it everywhere.
Need to save this post for future referenceI think it has been brought up or asked several times regarding the use of cam bolts for caster adjustment or going from a cam bolt back to a standard bolt.
Well, this is what it looks like after cam bolts have been installed….You can clearly see why a standard bolt will now not work. This is also why it is recommended to install adjustable control arms over cam bolts.
I know that look........
this is why I replaced the knuckles on my JL, thought it was bad ball joints, turned out to be the knuckle.We had a customer come in experiencing bad death wobble after a wheeling trip and this is what we found. This shows how the JL/JT aluminum knuckles can fail. The clip starts with the tire jacked up off of the ground, lowing it and then back up. You can see the lateral movement and gap where the aluminum knuckle at the ball joint opened up.
Duct tape on the ball joint shaft to fill the hole out should work fine. Save your customer some money too.We had a customer come in experiencing bad death wobble after a wheeling trip and this is what we found. This shows how the JL/JT aluminum knuckles can fail. The clip starts with the tire jacked up off of the ground, lowing it and then back up. You can see the lateral movement and gap where the aluminum knuckle at the ball joint opened up.
handle with white gloves
Saw those, they looked bad ass
It says "DOT" in the top left corner. That seems good.
Those are pretty sweet looking
This is what caused my DW on my JK. Not that bad though, although I could clearly see daylight between the knuckle and end forging when I let the tire droop.We had a customer come in experiencing bad death wobble after a wheeling trip and this is what we found. This shows how the JL/JT aluminum knuckles can fail. The clip starts with the tire jacked up off of the ground, lowing it and then back up. You can see the lateral movement and gap where the aluminum knuckle at the ball joint opened up.
