Installing Mopar hitch on 2024+ Rubicon JLU X
JamesWyatt
TLDR: For Rubicon JLU X models, you do NOT need to remove the rear steel bumper to install the hitch as the Mopar directions show. Jeep moved to (in 2024 I assume) putting in a simpler, smaller fill plate in between the frame and the steel bumper as a placeholder for the hitch. To install the Mopar hitch kit: 1) remove the two bolts holding in that filler plate, 2) remove the two bolts holding the bottom of the bumper, which releases tension on the filter plate, and 3) with a little wiggling, the plate just pulls right down and out. Toss the plate and the bolts. The Mopar hitch now just slides up in there effortlessly, and all the bolts go through the frame and line up super easy. Torque to spec. Getting the bottom bolts back into the bumper may require a little bit of wiggling with your socket or impact as the bumper will have slid backward slightly, leaving only half the bolt hole showing.
The older filler plate shown in the directions was much wider and also served as the lower bumper support brackets, which is why it has to be reused.
If like me you were unfortunate enough to buy a JLU Rubicon X that should have had the tow/aux package but didn't (either dealer was too stupid to order it or more likely Jeep ran out of the parts and wouldn't let them order it), installing the Mopar hitch after the fact doesn't follow the manual or any YouTube videos I could find.
The 2025 Rubicon X I bought had everything but the tow package (aux switched and hitch), but thankfully Jeep did include the trailer hitch wiring and receptacle under the rear bumper. It was annoying to have to pay $275 for the hitch kit (includes the two outer bolts/nuts and rubber Jeep cap) when the tow package is just $99, but at least I was able to find the JL I wanted, which the 2.0T 4-door in the X trim. I've heard but not confirmed that these X models that didn't have the tow package do have the wiring ready for the aux switches, and all that needs to be installed is the aux switch itself. I hope that means the alternator is also the tow spec one, but I haven't looked at it to be sure.
Another detail: Mopar makes a confusing number of hitch parts that are the same hitch in different configurations. They have the kit like I bought ($275), which has two welded bolts in the center and two holes on either end along with two bolts and nuts for those holes, and the rubber Jeep cap for the hitch. They have another kit ($108) that's the same hitch but with four welded nuts instead of just the center two. Pair that with the kit of four hitch bolts ($39), and you'll come out cheaper just without the rubber cover. I didn't realize that until I'd already received the full kit. The only caveat would be if you go that route, you may need to unbolt the existing tow plug receptacle/unit and swing it out of the way in order for the outermost welded nut on the driver's side to fit up into position.
Edit 12/7/25: Update to confirm on the 2025 Rubicon X units that didn't come with the tow package, they're just missing the actual hitch. These items are listed for my VIN per my account on mopar.com:
TRAILER TOW PREP PACKAGE
240 AMP ALTERNATOR
TRAILER SWAY DAMPING
700 AMP MAINTENANCE FREE BATTERY-CP
240 AMP ALTERNATOR
Thank you! I I have a 24 Rubicon x (2 door) that has the tow prep package. I installed an OEM hitch from a 2024 yesterday ( had to get 2 nuts from the hardware store as it’s missing the weld nut / bracket to put on the last 2 bolts). Thanks to your post , didn’t take the bumper off.
Questions I have :
1. I found this dangling in the back . I assume this is the connector that goes to the 7 way/ 4 way socket ? It was located on the passenger rear side.
2. Assuming this is the prep wire, do you have to wire this in the fuse box or is it already setup to just plug and play?
3. Do you have any idea on part numbers for the 7 way/ 4 way socket, bracket and wire to finish this install. Would like to stay OEM if I could.
Thanks in advance.
Questions I have :
Thanks in advance.
The trailer tow prep should include all the wiring and the hitch connector module next to the hitch on the driver's side. If you don't have this, did the dealer or former owner scavenge it for another vehicle? A random dangling connector seems suspicious – not sure Jeep ever leaves an open plug under the body like that. Are you sure your build sheet shows the trailer tow prep?
There shouldn't be partial wiring, but if that was what you were left with, your only retail option seems to be to purchase the entire wiring install kit, which may or may not plug into the connector you already have.
Maybe the dealer's service department could work with their parts department to figure out what you need, too.
My trailer tow prep came with this and all the wiring installed already – only the hitch was missing:
I removed mine when I installed the lod bumper.
Wiring harness removed up into the tail light. I doubt it will ever be used, and I will find it after I sell the jeep many years from now.
