wjtstudios
Looks great, how’s it running after the transplant
It's running as good as everLooks great, how’s it running after the transplant
I don’t know if your axles have unit bearings, but if they do, that might be your issue. Recall the issues I had last rubicon trip. I thought it was wheel sensors but it turned out to be worn unit bearings.It's running as good as ever
I have some speed sensor issues, sometimes throws it to limp mode, even with the delete switch.
I have to shut it off and restart, then it's fine again. I have recently replaced sensors, so it is probably a wiring issue, but I have looked in all the obvious places with no luck.
Thanks.I don’t know if your axles have unit bearings, but if they do, that might be your issue. Recall the issues I had last rubicon trip. I thought it was wheel sensors but it turned out to be worn unit bearings.
Racist.White Jeep news.
You do.Man I need to get to Moab.
Racist
Sounds like White Jeep privilege.White Jeep news.
it got 7 trails to Vengeance only doing 3.
Now that's funnySounds like White Jeep privilege.
