Jeep TJ Hazards Not Working
LetsGoMuddin
So I need an inspection this month and I figured out that my hazard lights don't work correctly. When I turn the hazard lights on only the front left signal functions. I have led turn signals up front with the led flasher. Has anyone else had this problem with their TJ and found a way to fix it?
Fixed my hazards! So the trick is to switch the hazards on and off until all the signals light up. It probably took me around thirty times before they all worked. It sounds silly, but by doing this the corrosion or dust build up in the switch gets removed and a connection is re-established. So if anyone's TJ has a problem with the hazard lights not working properly, give this a shot. :thumb:
