JK differential breather tube
bmkrinne
Anyone bought new tubing for your differential breathers lately? Where did you order it from?
I run an ARB diff breather in the front and in the rear behind the drivers side tail light. I’ve had good luck with them.
2015 JKUR AEV JK350
1985 CJ8 Scrambler
Measure the ID of the existing tube. Then go to an auto parts store, they have bulk rolls of that stuff and they will cut it to any length you want.
I just took the tubing to Napa and they gave me a recommendation and cut thr length I needed. It cost a couple bucks
What about that one-way valve on the outlet end of the line? Can you find that anywhere besides the dealership?
Thanks guys. I appreciate all the info and different options. More than one way to skin this cat!
I’ll remove my existing tube and start with the O’reilly’s down the street. If I can’t reuse the valves, you all have pointed me in that direction as well.
You all ROCK!
