NecessaryEvil
Good idea. I would try to turn the bolt around before cutting it. Imo
Thanks for answering some of the questions I had about this swap with your thread. Also, thanks for getting it done super quick. :clap2:
One of the questions I asked the guy in Texas who swapped in a JK front axle was if instead of messing with the WJ spring perches on a JK axle if it might be possible to make an adapter for the TOP of the springs and leave the area at the BOTTOM of the springs alone. From what I understand, the JK spring not only sit centered on the axle but about an inch lower than the WJ perches. An inch sounds like plenty of room for a top of the spring adapter.
I found another thread where the guy left the JK perches and just let the springs angle inward like this / \ . From what I read, he didn't have any problem with it. Is the difference in width between the WJ and JK spring perches the same as the difference in width between the WJ WMS and JK WMS?
What would you do differently if you had it all to do over again?
I dont have anything constructive to add to the thread. I just wanted to say, EXCELLENT thread!! and a VERY clean install! It is obvious you put a lot of time and effort into the swap, and it really shows! Thank you for sharing all the tech info you did! While I dont own a WJ, it was definitely still interesting to read! :2thumbsup:
Got my first opportunity to take this thing out for an extended test drive. Did about 100 in the mountains through slush and snow. Axle is fantastic :thumb: . The ProGrip brakes are remarkable, the ProSteer joints are very smooth while steering, and I'm loving the hi steer setup. A much more comfortable Jeep to drive now than prior to the swap. The downside is the axle isn't as pretty anymore.
You were going a 100mph in the mountains through slush and snow?! Lol.. That's great to here everything is nice and smooth
I got the caster down to 6.5 but drive line noise is still there. Not as constant, but it is still there and comes and goes. Pinion angle is at 1, so I'm not sure I can do much more.
I think I got the passenger-side bump stop pad figured out. I'll have to cycle the axle again to be sure. I installed a spacer right behind the track bar bracket, so it leaves about 3 inches of up-travel.
What are the tangible benefits of making the swap? Asking not knowing the ins and out of all the available axels for the WJ.
