Jk rubicon tcase problems
Well ended up setting my traildash to stock and used my flashpaq and I can shift through gears. Kind of stupid in my opinion their 2-300 programmer allows you to select tcase gear. But the 500 touch screen doesn’t...
You may have already thought of this but is your traildash up to-date? There may be an update that has what you need. just a thought.
Sent from my LG-LS997 using WAYALIFE mobile app
Hasn’t been updated since last year. But didn’t allow me to select tcase ration when I set it up. But also saw that superchips wants you to send in the pcm to get flash.
The AEV Procal that I have is the older version that does not have the Transfer Case Ratio feature, if I ever get a good deal on a Rubi T-Case, I will have to upgrade it, the cutoff date for that is 2014 when having to change that ratio became an issue.
