Mail Call - 1975 Jeep DJ5
So badass watching you go through this thing. What a cool Jeep. Ms Cleo predicts a plasma cutter in your future.
Actually, that floor board doesn't look nearly as bad as I've seen them. I bet a lot of the metal is still pretty solid. You could easily cut out the parts that have rusted through and the surrounding areas and then just patch it with new steel. You can then treat the rest of the floor pan with some POR15.
I’ll text you some better pictures when I get it cleaned up at some point and see what you think.
What’s the tube from the bottom of the carb intake back to the block for?
That could be it. It’s just like a dryer hose. I’ve never had a carb motor before so trying to figure it all out.
Okay, is it kind of a big accordian like hose? Like maybe 2" in diameter? If so, it's for emissions and should connect to the bottom of your air cleaner. It provides heat to a valve that opens up when your at operating temps. Of course, you really don't need to worry about this shit being that you have a 75.
Here are some pictures
The hose
Where it connects to the intake
Where it connects to the motor
That smaller shiny one? It's a heated air inlet. If you can get by without it, great. But it will help with cold starts before the choke fully opens.
Yeah that’s the one. Where would it pull heated air from if everything is cold? Or am I retarded.
As long as the vehicle starts, the air heats up quickly and pumps through that hose into the air cleaner. Inside that air cleaner is a metal door that opens allowing the hot air in. Once the engine reaches a good temp, the door closes and no longer needs the hot air and rather just sucks ambient air from outside through that snorkel opening. I'll try to find a diagram. Just like a lawnmower runs like shit when it's cold out, this feature helps the engine run well faster and sooner. Hot air atomizes fuel way faster than cold air.
You missed the 2nd question....
Ah makes sense.
Yup, this ^^^^
:cheesy: :cheesy: :cheesy:
Lol.
Here's some pics, but I doubt they'll help you. Nobody does this crazy shit anymore. But I think from the pictures, you'll understand.
Your best bet is to hook it up and see if it works. If it's been colder out, and Jeep starts fine, don't worry about it.
