Need Help?
Davidraider
So I'm very new to everything Jeep and have a question for you more experienced people. What is the name of the part I have pictured and is that supposed to move by hand. I've began hearing a knocking noise in the front of of my jeep when I go over bumps. ImageUploadedByWAYALIFE1426361352.194827.jpg
Hmmm, can you see any paint missing or metal that looks to be worn? I would go through all the bolts and check torque. Even from the factory parts get loose.
That is the adjustment for your tie rod. The bolt should be torqued properly, preventing the length of the tie rod from changing. You should not be able to turn it by hand unless you are trying to adjust it (after loosening the locking bolt)
