Personally, I would NOT recommend ANY tailgate tire carrier solution including EVO's. You've got to remember that when your tailgate is closed, there is a rubber gasket sitting between gate and body that will allow movement between the two. If you have a hard top, this can cause your glass to squeak and if you drive fast over rough terrain, you can have rattling and clunking cause by this. This is to say nothing about catching your spare when coming off a tall ledge or starting a steep climb. This WILL cause tailgate damage and again, if you have a hard top, can cause your rear glass to break. Trust me, these are things that I have seen happen with my own eyes.
Of the options listed, I personally would recommend the EVO body mount with corners. It is a bit more than Genright but you will get a rear end that is built solid. The Genright solution would be a second choice if you can't afford the EVO setup.
That being said, if you're open to other options, I might recommend the AEV tire carrier without the bumper. Unlike most of the other swing out solution out there, this design is the ONLY one that the spindle is mounted to the frame and is still only requires one hand to open up the tailgate. It's a clean and simple design and one that does NOT require you to run their bumper as well.
