Northridge
Sent from my iPhone using Tapatalk Pro
How much of a pain is it to get to the gate handle with 37s? Looks like the tire all but covered up the gate handle, I can imagine that can be annoying
Northridge
Northridge
More pics...
View attachment 291930 View attachment 291931 View attachment 291932 View attachment 291933
That’s what they came with? I’ve only had mine a couple months and they came with little bumpers not those.
Is there any way to switch the lugs so there’s 2 on the top and 1 on the bottom?
Several companies make a spacer that will flip the lug pattern. But you'll likely have to extend the tailgate bumpers if the Evo carrier uses them. I would not recommend the Zone one though. Studs stripped on my 3rd tire rotation due to shit cheap metal.
Solid. No noises. Gate opens easily.
35" Ridge Grappler on factory wheel hanging on it.
Did you have to use a wheel spacer using the factory wheels ? I have one on order and I am also running 35s on factory wheels.
Why would you want that? It would make it harder to mount the spare.
I just installed mine with single mount. Snugged it to the tire really good and worked fine from me. I only have one run with it on. I did 3 day trip on the Mojave trail and it did fine.So for those that have mounted the 4 gal rotopax on this I see some went with the single center mount and some have the two side mounts. Is there really any difference? I don't see why I would need to go buy the big universal dual mount plate if it will mount in the center just fine. I do worry about it being slightly unstable but I guess if you snug it to the tire it shouldn't move around a whole lot?
