New to wayalife
TheDuff
I would go coil lift, over spacer you get reduced flex on a bb, bekah I would recommend the rock krawler 2.5 stock mod kit from northridge4x4.com
Please enlighten me on how a budget boost gets "reduced flex" vs a coil lift... since you can run the same length shocks from the lift you suggested on a budget boost, I fail to see your reasoning.
Tanner505
Yes in my opinion, the spacers will give you lift but all your doing is adding space between the jeep and the coil spring, most say that spring spacers give a stiffer ride as well, but that's my opinion some love spacers I for one don't run them
TheDuff
You will have more active spring coils rather that the stock ones with a puck on top
And that matters why? If your using a 2.5" spacer up front with a 2.5" bump stop and add 1.5-3" lift shocks, you won't have an issue. So where is the reduced flex?
Warebear
Sweet, thanks.
TheDuff
And that's what you should have said in the first place, the reduced flex claim was rediculous
TheDuff
You get reduced flex with the spacer lift? Tell me how that works exactly. :crazyeyes:
Active spring coils duh....
Buy seriously, not sure how the stock mod system he recommended is going to allow any more flex than stock... it uses the stock shocks, no shock extenders, no bump stop extensions, no brake line brackets, and for what ever reason comes with rear sway bar links, and a front track bar. For $599.00 that's a rip imo. Claims to support 35's and 37's with flat fenders... yea, sure, on the road I'm sure it would be fine. As soon as you try to flex at all, rub rub rub... all this is of course, just my opinion.
OverlanderJK
Resident Smartass
Tanner505
I'm guessing you're unfamiliar with rk products, all rk lift heights are based on fully armored jks bumpers winchs ect... There 2.5 lift nets closer to 3.25 to 3.5 in the front and 3.5 in the rear and they do include spring retainers
TheDuff
OverlanderJK
Resident Smartass
Ok so then you are into a complete lift. You're going to need control arms, driveshafts, relocation brackets and more. The guy is looking for a budget boost.
