mudmobeeler
The max tow package had the 4.10s. Most new Rubicons are coming with 3.73s but you can still get the 4.10s if you order it, if the dealer ordered it, or if you get the tow package.
I don't see the ratio on the sticker on my door jam... Just tire size, passengers, total weight capacity...
Use this link:
http://www.jeep.com/webselfservice/...ountry=us&emailUrl=goToEmailForm%28%27R%27%29
Go to 'Equipment Listing' in the 'Your Vehicle' Section. Enter your VIN. Sometimes they'll list the ratio there, either way, free online build sheet.
EDIT: Call local Parts Dept with your VIN and they should be able to get it too.
Tried the link entered my vin nothing came up I'll try my local dealer see if they can pull it up
Use this link:
So I was in the same boat as you. Here is what I learned, first of if you are NOT putting on any heavy bumpers, winch etc and you don't do hardcore offroading, then the budget boost is perfect and cost effective. I ran mine w/ 35" and was quite pleased. I use my jeep as a DD and off road for hunting/fishing/camping etc, no rocks, and both the stock jeep and budget boost was fine. I added tires and lift to clear one obstacle on my farm, but otherwise no prob. I lifted also 'cause frankly I like the looks. Once I added bumpers, winch, I lost a lot of the lift and the jeep looks kinda "squat", so now I'm doing a proper lift w/ geo correction brackets.
As far as the power, I too have 35" KO2s and 3.73 gears, power is adequate in flat IL, but if you are in the hills/mountains, I think you will be wanting to re-gear. For the highway, I can cruise 65 or more no problem, but passing, the jeep will struggle.
Hope this helps.
I went back and forth between TF, EVO, RK, and AEV. I ended up ordering a RK 2.5" w/ Bilsteins and I hopefully will get it installed this weekend. I was told that the RK and AEV seem to have the best manners onroad and for my purposes this would be perfect. The EVO gets great reviews, but shipping to me was over $100....![]()
Maybe if we are lucky when you get it installed I can see a before and after picture. And a link or P/N to what you bought. :thumb:
