View attachment 236146 so here is my new axle!! I'm excited to get it home and start cleaning it up. Will most likely paint it black just so it looks clean. I an also going to go with the artec conversion kit.
Thanks guys going to get s battery NowHope it's a simple fix. Good luck.
Once I get the battery I will definitely check the alternator. I didn't even think to.Could very well be just a tapped out battery. Assuming that gets you going, might want to check the alternator to make sure it's charging.
I would like to. I am looking at buying a welder to do it now.You gonna be doing all the fabricating yourself? Awesome deal though congrats bud!!
I was going to do a long arm but a JK is in my near future.Awesome man love seeing tjs on here, I have a tj, xj, and a cj haha I just recently put a 6" long arm kit on my tj, just the control arms so far, need to upgrade shocks and springs still but haven't decided on what I want
Nope backed out on the coils. I ended up doing something a little different. But I wish I could keep it. With my first baby due in the end of march we will be in need of more roomDid you ever get the Synergy coils? And don't get rid of the TJ, we need a few on here.
So come to have it, I just had a really dead battery. Got it all changed out this evening but still going to take the alternator out tomorrow and have it tested to rule that out also.
glad it was just the battery, if you don't have a multi meter another easy way to test it is to run the jeep without the battery connected and if it stays running then your good.
Sent from my SM-G928V using WAYALIFE mobile app
Good to know. Thank you. I'll have to go pick one up and test it that way.Glad to hear that was it. FYI, don't go through the hassle of removing the alternator to check it. You can do this with a cheap multimeter with the alternator still Installed. A multimeter is a good tool to have regardless.
Start the engine. Turn on lights, AC, and any other large accessory in the jeep that would draw power on a regular basis (not the winch). Set your multimeter to the 12v setting or a setting that is similar. Put the red probe on the positive terminal of the battery and the black probe on the negative. Your meter screen should read at least 13.5 volts, 14 is better. That's it.
Also, if the alternator was bad, likely your battery light would have been coming on in the last week or so.
