OEM Front Bumper Winch Plate, Light Mounts, and Grille Guards - Made in USA
Learn More: http://www.rockhard4x4.com/factory
With our RH-5010 Winch Plate, you can add even the biggest winches to your factory front bumper. It installs in minutes, requires ZERO drilling, welding, or cutting, and you do not have to relocate your vacuum pump on newer 2012 - Current 3.6L Jeep JK's! In fact, you don't even have to fully remove your front bumper during install! Our RH-5010 mounts directly to your frame rails plus uses special, laser cut tabs that brace against your factory installed front bumper tow hooks. Winch sold separately.
Now that you have your RH-5010 Winch Plate installed, protect your grille plus add aftermarket lights! We have three different hoop styles that give your grille the protection you need from tree branches and other trail debris plus, depending on part number ordered, welded on light tabs! Our tabs are designed for either a 10" LED light bar or individual round or square lights. These hoops mount to laser cut holes built into all RH-5010 Winch Plates.
RH-5013 - Shorty Grille Guard and Light Mount Hoop for RH-5010 Winch Mounting Plate for Jeep Wrangler JK 2/4DR 2007 - 2015. Fits standard winches without air compressor built in. Requires RH-5010 Winch Plate. Winch, winch plate, and lights sold separately.
RH-5014 - Tall Grille Guard and Light Mount Hoop for RH-5010 Winch Mounting Plate for Jeep Wrangler JK 2/4DR 2007 - 2015. Fits taller winches like the Warn PowerPlant or other winches with a built in top mounted air compressor. Requires RH-5010 Winch Plate. Winch, winch plate, and lights sold separately.
RH-5015 - Shorty Grille Guard Hoop for RH-5010 Winch Mounting Plate for Jeep Wrangler JK 2/4DR 2007 - 2015. Standard height winches without air compressor built in. Requires RH-5010 Winch Plate. Winch, winch plate, and lights sold separately.
The factory front bumper on your Jeep JK simply does not allow you to mount aftermarket lights. You can upgrade your fog lights (if equipped) but those options are very limited. If you want to add real lighting to your factory front bumper, like a 10" LED light bar or individual lights, look no further! We have bolt on options that require zero drilling, cutting, welding, and install in minutes. Each are made from steel, arrive powder coated black, and have gorgeous aluminum end caps already installed to keep debris and water out.
RH-6060 - Light Mount for Factory Front Bumper for Jeep Wrangler JK 2/4DR 2007 - 2015. Fits most 10" LED light bars or individual lights. Lights not included.
RH-6061 - Light Mount with Grille Guard for Factory Front Bumper for Jeep Wrangler JK 2/4DR 2007 - 2015. Fits most 10" LED light bars or individual lights. Lights not included.
Rock Hard always has awesome products like this. I love my bolt-in cage and skid plates.
