Oh my freaking jeep
tkkim
ImageUploadedByWAYALIFE1395354671.117316.jpgReplace sensor and bulb exact a week ago and got same problem again..
2012 jku 40k mi on it.
I don't know where is standard of proudly mad of usa on my jeep.
you have regular bulbs? mine said that when i put led lights with no load resistor.
You sure the lamp is completely seated? I know when I had to swap my taillight lamp, I had to reseat it once or twice. Sometimes an intermittent connection will ping as a burnout.
does your light work? i unplugged my battery and that message went away.
Actually if the signal show consistently, it'd be better.. It's on and off ... May be connection problem. Last time dealer said had some cam sensor problem
Cam or crank sensor has nothing to do with your turn signal.
surprised no one mentioned blinker fluid yet:crazyeyes: iwas gonna say if you have a tow package check the harness by the muffler, but sounds like something different with sensors and stuff.:thinking:
I just bought a quart of blinker fluid from some guy in China. Only $59.99. Its been a month though...strange it has not arrived
I don't think my jeep has tow package also i changed my muffler to dynamax one..
The shipping fluctuates a lot... sometimes on schedule, sometimes off...
They replaced a cam sensor which was causing your check engine light to come on. Not related to turn signal lamp replacement.
I'd take it back since you are still having issues with the lamps and have them fix it right.
Thanks! But worse thing is engine light problem happened again after fix that..
Like this.. show up with cute slip warning sign.. Sigh
I'm going tomorrow hope they can figure out..
Your CEL could also be just informing you about your turn signal problem. Is your engine running OK?
