Random (non-Jeep) Shit You’re Working On....
Please don't tell me that I am wrong again, but this looks like excellent work to me!
Is the lighter color of the doors due to being fresher wood, or is the wood on the walls in some way different?
sigh, thank you Bob
Yeah, the wood is from the same batch - it oxidizes over time and will eventually turn gray with exposure to the sun. The difference is roughly two weeks between the wood on the shed and the doors
Had some noisy water lines at 4am when the sprinklers would kick on. Swapped out the cheap clips for some noise isolation ones. We will see how it works. Half of the of the old clips were broken anyways… should’ve taken a before picture.View attachment 426586
Original clip:
Noise isolation clip:View attachment 426588
Nice! There must still be some valve or junction which is producing the turbulence and thus the noise. It would be good to identify it. Perhaps replacing that part would remove the source of the noise.
Original clip:
When the solenoid valves feeding the sprinkler heads open & close they cause water hammer. If you install a soft seated check valve before the solenoid valve it'll help absorb the hammer.
Thank you for that tip! I noticed the noisy check valve. I didn’t know I had an option to change that out.
Finally fixed this POS. Crank no start after dying on the road while driving. Was getting fuel but no spark. Checked and/or replaced everything around the sun including cam and crank sensors, spark plugs, coil packs, fuses, main relay, immobilizer… probably something else I forgot.
Anyway also found that when hand spinning the crank and looking through the oil cap, the camshaft wasn’t spinning with it. Okay, timing belt mostly likely snapped or skipping time. Popped the cover and found that’s the culprit. Wasn’t thinking of it at first because cranking sounded so normal.
Water pump is also internal so had to be replaced - also did pulleys and serpentine belts (has 2, power steering + AC and alternator + water pump) and valve cover gasket obviously. All buttoned up and honestly as good as new with all these new parts. Took a few months to accumulate the time to get this done but happy to have it back up and running well to give the Jeep a breather once again.
All this means is more Jeep parts sooner! 😎
Anyway also found that when hand spinning the crank, the camshaft wasn’t spinning with it. Okay, timing belt mostly likely snapped or skipping time. Popped the cover and found that’s the culprit. Wasn’t thinking of it at first because cranking sounded so normal.
Water pump is also internal so had to replaced - also did pulleys and serpentine belts (has 2, steering + AC and alternator + water pump) and valve cover gasket obviously. All buttoned up and honestly as good as new with all these new parts. Took a few moths to accumulate the time to get this done but happy to have it back to give the Jeep a breather once again.
Nice job man, that’s quite the undertaking! You still planning to sell it?
Water pump is also internal so had to replaced - also did pulleys and serpentine belts (has 2, power steering + AC and alternator + water pump) and valve cover gasket obviously. All buttoned up and honestly as good as new with all these new parts. Took a few moths to accumulate the time to get this done but happy to have it back up and running well to give the Jeep a breather once again.
Do the SBC swap and light her up.......
Thanks! Wasn't fun but it's so rewarding to get shit done and hear it turn over for the first time in months.
On the fence. Of course, the whole time working on it and seeing it sit I was like "F this car." and "Why did I buy this POS?" but after driving it again I remembered how much fun it is to drive and how I get almost 30mpg. Plus track days with my friends who have these cars as well were fun too. We'll see.
Edit: In the car's defense, I got ahold of the previous owner and found it was the original timing belt. I'll take it for 150k miles.
