What do you guys think about these they were on this jku at the auto show
Yeah they've mounted the tire in the standard safety bead position but fitted the beadlock ring instead of the trim ring. Looks kinda goofy but that's what happens when you don't read the instructions
Forgot the pics
That moment when everyone tells you your 6.5 inch lift is too much and then you part next to this beast that sits about 4 inches higher than you.... [emoji15][emoji58]
6.5 inches IS too much lift.....
Wow just realized how far those bolt heads stick out. A couple trips through the rocks and there would be nothing left! Good news though when you rip off all the bolts and are left with a flat you can pop the tire back on the the dot approved side of the rim
Knew I should have went with heated :banghead:View attachment 189099
So is this the only difference between heated and non heated trucklite lenses? It keeps the ice off? The price difference between the two seems a little steep for something you can do with your hand.
View attachment 189172 happy jeep is better than those angry eyes
