J
JKDream
Guest
I would be doing a suspension lift. That said, are you suggesting I take a look at a new drive shaft over creating more space by moving/dealing with the exhaust?
Any concerns with spacers? Seems like an easier install. I don't mind cutting the exhaust, as instructed to install the Rancho kit, but you only get one shot to get it right.
Spacers are missing the point. Your slip-joint boot will contact, and that's fine - the driveshaft will not become unusable if the boot tears.
The main reason why spacers aren't good is because it doesn't solve the angle of which your driveshaft will be sitting at.
When you lift, your axle rotates and angles become steeper, this causes the CV joint to be constantly stressed and eventually wears out.
Regardless of an exhaust spacer, this still happens. When the CV boot tears, you will lose all of your grease in the unit, and it will eventually seize.
