Recurring Starting Problem
Jameso
So...2023 JL, non Rubicon, just about 6k miles. 2d time not able to start. Will not crank, won't jump start. Batttery shows good. The 1st time it jump started, then in the shop for several days, "nothing wrong:". This time had to tow it in on new years's eve. Any ideas? Thanks!
Could be a grounding issue. Check the ground cables that are bolted to the frame in the front passenger wheel well… make sure they are tight.
jeeeep
There's another post for a JL that the ground to the alternator was loose and causing similar issues to what you're describing
jeeeep
Found the post with similar issue:
