Replaced clutch no crank
Zach1215
So after an extremely long process of swapping my clutch it won't start now, I had my dad help me with this and he was the one who took my starter off, after looking at diagrams it just looks like I'm suddenly missing wires, can anyone give me an idea of what's wrong?
Sent from my SAMSUNG-SM-N920A using WAYALIFE mobile app
Put the trans in neutral and make sure the engine turns by hand and isn't binding. If it is not turning, something mechanical isn't right.
If that's good, pull the starter and put power directly to it to see if it is bad or not. Your big positive cable goes on the large terminal and then you should have a small wire that goes from the ignition switch to the small terminal on the starter. If starter is getting hot, it is pulling too many amps. Check that positive cables aren't shorting out on anything and that motor is turning smoothly.
