Rock sliders
Thumper291
Hy people, I just got a 2017 Willys and it has rock sliders on. My question is can I leave them on and add a step to the side also.
If you are referring to the stock sliders then the answer is yes. Several companies make body mounted sliders that supplement the rubi rails and can be used as a step.
Yup, there are. I have a 17 Willys too and added sliders that stick out enough they act as a step. They work nicely with the stock sliders.
Sent from Earth to Space and back...can ya give it a second!? WAYALIFE mobile app
You can. There are a couple options like those mentioned, but they are also prone to bending up against the Rubi sliders and in some cases have damaged the pinch seem.
Not sure your budget, but you may want look at the LOD sliders which can be bolted on in place of your Rubi sliders. The LoD have a built in "step" and well.
