JKDriver
I see there are quite a few people here running the EVO DTD set up. Having determined that this will be the ultimate suspension for the varied driving I am going to be doing, I have some questions.
First, here is my JKU now. Poison Spyder Crusher Flares, RK 2.5 Max Travel (upgraded to all 8 arms) w RRD's w/ reservoirs, Teraflex speed bumps. The stance is great, on road handling is good, off road handling is good as long as you are going slow.
First, I know that the DTD can be set at a low ride height, like 3 inches. At that height, what is your up travel? For washboard trails and fast bumpy stuff (not desert running) what do most of you set your ride height at? I know its adjustable, but just looking to see what a daily ride height would be. I ask because this is my daily driver of choice and I like a lower center of gravity, besides which my wife is short and I have 2 younger kids.
For the time being, I want to stay with my 35's, although when these wear out I will move down to 17 inch wheel, either a bead lock or a wider wheel with the correct offset.
Second, given my set up and the ride height, is there anything else I would need to add/change? Drag link flip? Does it look like there is enough wheel offset to fit the DTD?
Also, I have seen a lot of flexed out systems. Would anyone like to share some shots of the systems on flat ground?
Thanks!
Dave
Thanks!
Dave
