Spotter and driver basics
noroad
So i have been out on a couple of runs know outside of my club and have seen a growing interest in the sport! So one part about this sport i feel that is being left out more and more is the skills of driving and spotting! This is not the new guys fault it is simply the over looking of the vet's! when driving there are some basic terms that should be known before hitting the trails, no matter if its a green or black/ level 1 or 10 trail. This should be a place for people to post helpful tips and new jeeps to ask questions(im hoping).
Basic terms
1) turn passenger = this means for the driver to turn the wheels to the passenger side of the jeep
2) turn driver = turn to the driver side ( this will take out the confusing my left or your left problems)
Here are some basic rules to help that i have seen!
Rules For Great Spotters & Great Drivers
There are a lot of fine points to the art of spotting. Great spotting, truly refined expertise in this area is something that takes a lot of time and a lot of experience to learn. It is experience that one gains from watching others and trying to apply what you have learned from watching.
It would not make sense to try to write about the finer points of great spotting. However, there are a few things that all spotters should know from the start that pave the way for a safer and more enjoyable trail experience.
Drivers should be as knowledgeable about the basic rules of spotting as the spotters are. Drivers have a different set of spotting rules to follow but the rules for drivers are just as important as the rules for spotters.
Very little has been written for drivers on the subject of spotting. Hopefully that will change with this article since the second section is dedicated to the driver.
When both sides follow the rules the trail becomes a much smoother place.
(Note to the would-be spotter: Reading this article does not make you a spotter. It is designed to help you understand the dynamics of spotting more fully. Any given trail-run normally has one or two club assigned trail leaders or spotters. You will be a lot more liked when you are on the trails if you acknowledge the hierarchy and organization of a run and not try to subvert it.)
RULE NUMBER ONE:
Rule #1 of spotting, the first rule of ALL GREAT SPOTTERS is this...
* A good spotter will always look for another person who is already spotting the driver and will then do nothing but wait to be asked for help.
Think about this sentence for a minute. Virtually EVERYONE on a club run can, and should, be a spotter but only if they are all reminded of that rule. Following the Spotting Rule #1 will keep things a lot more organized than those unruly times when EVERYONE is yelling directions.
RULE NUMBER TWO:
This could be rule #1, it is a toss-up. It is the only rule I see broken more than rule #1. It seems like we forget, many times, to bother to ask the driver if he would LIKE to have a spot. There are many drivers who will know their truck well enough to be able to just know where the rocks are. Then there are guys who just don't want to have a spotter.
* A good spotter will always ask the driver if he would like to have a spot before he starts issuing signals.
RULE NUMBER THREE:
A good spotter knows that there will always be others yelling directions from the trail side and he knows that there will always be a newer driver who finds that confusing. This being the case, rule # 3 of great spotting is...
* Create a bond with the driver. Make sure he is locked on to you and only you.
This is done by taking the time to walk up to the driver and have a small driver's chat.... "Hey, I am going to spot you through this. I want you to focus on me and tune everyone else out, OK?" It is funny but dive instructors do something very similar to this when bringing a student down for the first time. They use two fingers in the shape of a V and move them from their eyes toward yours while locking in your gaze to theirs. For some odd reason they have learned that doing so actually helps a new diver get through the initial anxiety of being under water and being able to actually breath.
Creating a bond with the driver goes a long way to help him get through those times when there are a lot of people trying to spot.
RULE NUMBER FOUR:
With engine noise, other vehicles, people talking and the distance between the spotter and the driver who may be in the middle of an obstacle verbal signals are not always the most effective way to communicate.
With that in mind, rule #4 of great spotting is...
* A great spotter will make sure that the driver understands the hand signals he uses. You can do this while you are having your little drivers chat.
Here are a few examples used in our club...
STOP: We use a closed fist for a stop.
TURN RIGHT OR LEFT: We point with the index finger (or thumb) to the left or the right when we want the driver to turn the wheel and, if he is not turning far enough we point and push the finger in that direction at the same time.
ADVANCE: We extend an open hand so that the palm is facing AWAY from the driver, we then fold the thumb in so that it is not confused as a directional signal, and, keeping the fingers together, we wave the fingers inward a repeating manner.
REVERSE: Using one or both open palms, FACING the driver, we make a pushing motion in a repeating manner. When doing reverse we may go to the back of the vehicle to help the driver back up safely.
TAIL SPOTTER:
The spotter may want to have someone at the rear of the vehicle to keep an eye on things. This person will only make a signal to STOP when the vehicle is in a situation where a stop is needed. The tail spotter will not do any actual spotting for the driver.
DRIVER RULES FOR GREAT SPOTTING:
At this point the article has been mainly about spotters but DRIVERS can have a HUGE part in how organized or disorganized spotting is around his vehicle. Oddly enough, drivers can do a lot to encourage great spotting. In fact, when a driver knows great spotting he can do certain things that can force a spotter to follow the rules without ever saying a word.
Neat, huh?
DRIVER RULE NUMBER ONE:
Whether or not he will be spotted is up to the driver and the driver should be the one who decides if he wants a spot or not. The means that driver's rule #1 is...
* Ask for a spot or specify that you do not want a spot.
If you do NOT want a spot it is sometimes helpful to say it loud enough to be heard over all of the noise of the run (or, really, to make sure everyone hears you).
DRIVER RULE NUMBER TWO:
The spotter may not instinctively know that if he stops moving you should stop moving. In fact, he may even ask you why you stopped moving. Here rule #2 comes in...
* If spotter is not moving or directing you in some way then don't move. It should always be like this...if the spotter moves, you move, if the spotter stops moving, you stop moving.
DRIVER RULE NUMBER THREE:
In the event that your spotter does not practice Spotter Rule #3 about creating a bond then you, the driver, can make it happen. Driver rule #3 is...
* Lock on to your spotter and tune everyone else out.
This accomplishes another effect. With the driver and the spotter locked observers (would be spotters) quickly learn that you are not listening to them, you are listening to the spotter. Once they catch on to this they will start yelling at the spotter and not at you.
IN SUMMARY:
For the record, a lot of these issues would not need to be brought up if more folks just backed off spotting and focused on watching the spotter and learning from him.
Fortunately, it is a lot easier to teach drivers how to pay attention to spotters and to teach spotters how to get drivers to focus on them than it is to teach every person on every trail-run to not try to help with spotting. It is just human nature to help out. (Non-spotters, are you getting a message here?)
This being the case, our expectations of spotters and drivers needs to be set correctly. When both the driver AND the spotter are on the same page all the yelling in the world won't make a darn bit of difference.
Woody3
Well written and thought out. Thank you for putting our trail frustrations into written words.
Keep your head low and your powder dry.
noroad
That was my reason for posting, but all the credit is not mine i add things but it was from my local club tips and tools that i thought really need to be shared as i havent seen it on here yet and the amount of new jeeps is growing faster on here then i have seen!
NV375
I need to get over the bad experiences I have had over the years with bad spotters on the job. I know how important spotters can be but I have trust issues after bad experiences at work in trucks and equipment. I have been know to put someone else in the seat of my rig so I could spot. That involves a some different issues. My wife has driven over larger obstacles than me in our '14 JKUR so I could spot. I am looking forward to being spotted by some WAL trail vets.
swag247
Rule 1... Don't spot if you have no clue what your doing. Don't put the driver and his equipment in danger. My damaged JKU and I say this from experience... just saying.
This was a good read...
I will add that many spotters (like me) will only give you one chance at ignoring directions or not listening before they assume you are okay and leave you. If you tell someone you would like them to spot then trust them. If you don't want them to spot then tell them that. My feelings will not be hurt. I understand your rig is important to you. If you are uncomfortable with a spot or my spotting say so. We can laugh about it around the fire later!
I personally only allow my wife to spot me and she only listens to me when she's at the wheel. We understand each others body language and communicate well. There was once an instance she asked for another's insight on the best line for me... but she was still the one to bring me through.
noroad
I deff agree with this, they need to walk before they can run some might say! This is the reason i have posted this and your advice will be seen and your damage will be heard now! hope your experience was nothing real bad(in safety meaning)! thanks for sharing!!
noroad
Very cool that is what i am trying to get people to see, Like you said you have a bond with your wife makes the spotting easier and more trusting! Also another huge point that if you are uncomfortable with a spotter ask for another most people will not take it the wrong way (if they do they are a baby and it your rig, be safe)!
cozdude
Guy with a Red 2-Door
Thanks for this Andrew! we had some good team work this weekend with us spotting others. a good example of what you mentioned to leave only one person to spot was when i was spoting scott (grnhorn) thru trail 8. i wasnt 100% sure on the right line so i handed the reigns back over to you since you spotted me thru with no issues. you didnt chime in till i asked you if you wanted to spot him. it was some good team work! :thumb:
noroad
It was and we made it throw the day with no problems and we both had a system going that worked! This made for a great day and safe day!
GRNHORN
Great post Andrew.. I can tell you from a new driver (Jeeps Offroad) perspective that it is important to know the language that the spotter is using. The spotters that I have had have been great.
This past weekend Steve (cozdude) and Andrew (noroad) did a great job spotting not only me but everyone else through the trails.
Panda
Great thread! A good spotter can make a rough section feel like a plain dirt road to the driver :thumb:
JKWrang
I've had a lot of spotters in my time and you have to trust your spotter -- but the spotter needs to know what he is doing.
I have had good spotters and bad. I was driving an MRAP one time and placed all my trust in the spotter and he backed me into a Humvee. :grayno:
I have also had spotters who corrected my instinct to cut the wheel and it wound up paying off (saving my front bumper).
The moral of these stories? Spotters and drivers alike must know be able to have a good grasp of what is going on and be tuned to only one another as said in the OP. That said, if you - the driver - do not feel comfortable doing whatever your spotter is having you do - DO NOT DO IT.
Do not be afraid to speak up and say you don't have the skill, confidence, or good feeling about the obstacle and need more help than a spot.
My $.02
Sent from my SM-P905V using WAYALIFE mobile app
