super_c_06
View attachment 192027View attachment 192028
I'm running 2 JL audio w0 10s with a jl jx500 amp. Takes up my trunk but sounds great
How do the down firing subs sound with the top off?
Subs are omnidirectional for the most part so I assume they would work well
How easy is the Kicker to wire up? My jku didnt come with a sub and I have been thinking of a few spots to mount something small.
i went from small box, big box back to small box
I actually had Bestbuy install it for me, but looking at the instructions there's only two wires hook up. The power wire which they tapped into the cigarette outlet and one the goes to the head unit.
Hmm okay maybe Ill just order one and figure it out. I want to keep the stock headunit for a while yet so Im sure it cant be too hard.
Anybody here running a JL W3? I've saw quite a few people have good luck with these in the stock enclosure. Think it takes some minor modifications in the inside to clear without a spacer ring. Nothing too crazy, though.
I'm thinking about selling my 430N to go to the new AVIC-8200 and upgrading all my speakers. Would run this off a 5 channel JL amp.
Can you fit a w3 in there? Or are you referring to a tw3
The w3s are badass it would obviously sound a lot better in a 3/4 inch MDF box but it'd be worth a try
People are using the W3v3. The enclosure can be modified to fit anything under 5" depth, as I understand it. What exactly that entails, is something I guess I'm going to learn. While a custom enclosure might end up making it's way in my Jeep, I'm going to try my best to avoid that. If it sounds horrible with the typical dynomat approach, I might attempt "gutting" the enclosure and glassing the inside.
EDIT: Also, the JL recommends an enclosure volume of .3 cubic feet for the W3, which is about what the inside of the factory enclosure is.
This is it mounted under the passenger seat between the seat rails. I used a mounting bracket that a guy makes and sells on eBay, it works out really nice. View attachment 192012View attachment 192013
Does your Jeep have the front seat the lifts up when you fold it forward? I have a 2015 JK 2-door and the front seat lifts up off the rail slightly in order to give more room for someone to get into the back.
