TECH TIP : Jeep JK Wrangler Headlight Adjustment
MNMudder
As stated before, the Trucklites produce an X pattern at 25'. So, should the center of the X be at the 3' mark, or the tops of the "legs" of the X be at 3'?
Wethy
did this last night and i used my low beams and the light is definitely better but am curious as to whether i should have used my Highs or my lows, just looking for a confirmation
cheers :)
lostcolorado
Hey. Guess what. The search function works!
:thumb:
Just installed LEDs .........exactly the info I was looking for.
HeWhoDares
For those with the electric height adjust button in cab... If your headlights are uneven you can adjust the height using the white dial on the back of the headlight adjusting motor behind the headlight. It's the white dial in the pic. The torq screw as mentioned earlier really only moves the headlight horizontally. 20181108_193929.jpg
Sent from my SM-G930F using Tapatalk
