Teraflex Leveling Kit Squeak
Tcsmith
I installed a TF Leveling kit on my 2014 JKU this weekend, and now every time I come to a stop or turn the wheel to full lock it squeaks. I've read about greasing the new sway bar links, is that possibly the source of the squeak or could it be something else? I've torqued all the bolts back to factory specs, so I'm not sure that the problem is.
It might help to first identify where the squeak in question is coming from. If you can reproduce it by turning your wheel to a full lock, have someone do that for you while you listen and feel for the squeak. The squeak will give off a vibration. Once you find it, it'll be easier to point you in the right direction.
