Mtb275
All 5 done. Heading to tire shop for balance in the AM.
Nice bud!! What's the latest on the rear track bar issue?
Sent from my duck blind.
Murph Murph is on 37's!!!!
All wheels balanced and mounted. All wheels took a little weight, each took less that 6oz.
View attachment 238697 View attachment 238698 View attachment 238699 View attachment 238700
Nice! That amount of lift looks perfect for 37s! Great choice/job!
Nice! Good work the past couple of weeks!!
Just caught up! Helluva build, love the color combo! :thumb:
I got some work set up for tomorrow. Need to change the front pinion seal.
Also, I'm worried I might have a bent flange on my driver rear. Getting a grinding sound when driving,WuT...WuT....WuT, etc
When I hit the breaks it goes away. Going to pull the wheel check rotor first and then pull caliper and rotor to check flange.[emoji19]
If you jack up the rear axle and run the Jeep, you'll be able to see the wheel wobble if the flange is bent.
Yep, that's the plan. It's not too bad of a sound, but did it with stock wheels/tires and the 37's. I had my wife drive it, while I hung my head out, I can see a slight wobble and probably shouldn't since I had the tires balanced.
I'm staying positive, I might just have a trail spare now[emoji23]
